2funky_105078's avatar
Aug 25, 2017
ASM heavy -URL and stress based
Hello,
is there a specific difference between stress based DOS protection (which looks at latency of servers) and heavy-URL?
thanks
  • nathe's avatar
    nathe
    2funky, by setting up Heavy URL protection you are highlighting those URLs that may be susceptible to high resource consumption even if the metrics around other DoS criteria aren't met. So, for me, they are complementary but ensures ASM has a special eye out for particular URLs.
    N
