ASM from transparent to block mode
We are planning to move ASM to blocking mode from transparent mode. Need suggestion on what precautions we need to take so we can avoid outage? will it block all the violations I am seeing or just the one which are defined in signatures?
Thanks.
- Janek_42109
Hello,
When switching to transparent to blocking, in your blocking settings, you can set your violation list only to Alarm and uncheck Block to check if you have any issue. And Then you check again Block action in your violation list when all is ok for you.
- cjunior
Nacreous
In addiction, Don't forget the block will occur when you enforce the objects(url, parameter, cookie, etc). So, when you change to block also remember to review the staging flags.
Regards - Chris_Grant
Employee
If you are paying attention to your learning suggestions, you should already know what traffic is being flagged. Turning off blocking in your blocking settings is really not going to get you anything you wouldn't be getting under transparent mode. If you are not seeing legitimate traffic being blocked while in transparent mode, going to blocking should not cause any issues.
