member123_60341's avatar
member123_60341
Sep 05, 2009
ASM error - policy builder is not running
We are having two LTMs with ASM in active/active mode (ver 10.1).
We have deployed security policy using policy deployment wizard.ASM is able to detect the file types and parameters.
Problem:
After some duration, the policy builder stops running.
Then we have to reconfigure the policy.Again it runs for sometime and then again the policy builder stops running.
Error: Policy builder is not running.
Any ideas what could be the possible cause?
Rgds./
Joe.
  • hoolio's avatar
    hoolio
    Hi Joe,
    I don't use the Policy Builder so I'm not sure why it would stop running. If you don't get an answer here, you might try opening a case with F5 Support on this.
    Aaron
  • zafer's avatar
    zafer
    Joe
    you can check log files and process it can be zombie process
    also you can stop start asm for workaround solution
    Note: Best practice deployment is Active-Standby
    zafer
