Torti's avatar
Torti
Icon for Cirrus rankCirrus
Nov 28, 2012
ASM - SOAP attachment problem
is anyone familiar with SOAP attachments?
I try to implement this in a webservice, but I allways get the error message: xop:Include, Element is not not defined in schema
Does the ASM doesn't support MTOM attachments with xop:include, what is recommended by w3c?
Thx & regards
    • Torti's avatar
      Torti
      two ar ebettwer than one. perhaps, some more customers have the same issue and will open a case. Thx
    • J_LE_42749's avatar
      J_LE_42749
      yeah, still no change... looks like it's not a priority to REALLY support famous protocols used by many applications nowadays...
  • Hi guys, I have the same problem. I'm going to open a case too, but before I do it I'd like to ask you. Is there any change regarding to MTOM support? Thank you.
  • So, there is generally no support for multipart content in combination with web services - after years.
    For me, this sounds a little bit strange, because it is standard since 10 years.
    Is there no one, who is using this technology around the world?
