cymru81's avatar
cymru81
Jan 15, 2014
APM Split-tunnel & ACLs
Am using APM and have setup a network access tunnnel. It is a split tunnel and the address spaces are (for example):
10.0.0.1/255.255.255.255 10.1.0.1/255.255.255.255 10.1.0.8/255.255.255.255
I also have an ACL that allows access to these individual IPs on port 80. Should i not need an ACL as the tunnel is set to split and i want all traffic that isnt one of the above IPs to go direct using the native connection?
  • There is no need for an ACL as only traffic directed to those addresses will route up the VPN connection.
