Peter_Baumann_5's avatar
Peter_Baumann_5
8 years ago
Solved
APM not ready for HTTP/2 ?
Hi all,
I have a config here with APM and users are login to a full webtop.
Version used is v13.1.0.1.
Now, for a test I changed the VS to support HTTP/2 and added a http/2 profile to the VS.
When we connect we get the following error in /var/log/ltm:
Jan 15 14:14:19 bigip1 err tmm1[12276]: 01220001:3: TCL error: /Common/_sys_APM_VDI_Helper  - can't read "tmm_apm_client_type": no such variable     while executing "if { ($tmm_apm_uri_path equals "/broker/xml") || ($tmm_apm_user_agent equals "VMware-client") } {             set tmm_apm_client_type "view-xml"      ..."
So is APM not HTTP/2 ready yet?
Thanks for a reply, Peter
  • Hello Peter,
    are you using the full-proxy settings?
    If yes and based on https://support.f5.com/kb/en-us/products/big-ip_ltm/manuals/product/big-ip-http2-full-proxy-configuration-14-1-0/01.html, you'll find some configuration constraints: - An HTTP/2 full-proxy configuration works with BIG-IP Local Traffic Manager (LTM) only. The configuration is not supported on any optional BIG-IP modules.
    • The OneConnect and HTTP Cache features are not supported.
    • The HTTP/2 protocol is incompatible with NTLM protocols.
    • For session persistence, only the Cookie persistence method is available.
    • In high-availability configurations, connection mirroring is not supported.
    • The iRule commands session and table are not supported.
    At the moment, full-proxy http/2 support is only available for LTM!
  • mnagel_63130's avatar
    mnagel_63130
    Historic F5 Account
    Hello Peter,
    • Peter_Baumann_5's avatar
      Peter_Baumann_5
      Hi Michael,
      Yes, full proxy settings.
      Thanks for the update with the v14.1 :-)
