apm irule, unexpected result - variable scope not standard?
I have the following iRule
when RULE_INIT {
set entrypoint "/Reports/Pages/ReportViewer.aspx?%2fWelcome&rs:Command=Render"
set backend_host "aa.bbb.com"
when ACCESS_POLICY_COMPLETED {
if { [ACCESS::policy result] eq "allow" }{
set initialpath [ACCESS::session data get session.server.landinguri]
log local0. "POLICY_COMPLETED - host=[ACCESS::session data get session.server.network.name] - path=$initialpath"
if { not ($initialpath equals $entrypoint) }{
ACCESS::session data set session.custom.entrypoint.redirect "1"
log local0. "setting session.custom.entrypoint.redirect var to 1"
log local0. "Acces_policy_compl, entrypoint value= $entrypoint"
when ACCESS_ACL_ALLOWED {
if { [ACCESS::session data get session.custom.entrypoint.redirect] eq "1" }{
HTTP::uri $entrypoint
log local0. "Reporting : rewrite initial URI to $entrypoint done"
ACCESS::session data set session.custom.entrypoint.redirect "0"
set vs_host [HTTP::host]
HTTP::header replace Host $backend_host
in the logs I see
tmm1[8580]: Rule /Common/reporting_apm : POLICY_COMPLETED - host= - path=/
tmm1[8580]: Rule /Common/reporting_apm : setting session.custom.entrypoint.redirect var to 1
tmm1[8580]: Rule /Common/reporting_apm : Acces_policy_compl, entrypoint value= /Common/
tmm[8580]: 01220001:3: TCL error: /Common/reporting_apm - can't read "entrypoint": no such variable while executing "HTTP::uri $entrypoint"
variables are not passed from ACCESS_POLICY_COMPLETED to ACCESS_ACL_ALLOWED.. As a "workaround" I've set APM variables. Any reason why?
why the entrypoint variable cannot be read in th ACCESS_ACL_ALLOWED event and has a "corrupted" value in the ACCESS_POLICY_COMPLETED ?
Would be thankful for any tip
Alex
- Michael_Jenkins
Firstly, to get an understanding of the flow, you can check out this article describing the APM event flow. Because you won't have a single request that ends up hitting both
andACCESS_POLICY_COMPLETED
, you can't share variables between them (since variables live and die with the request). Session variables are more persistent and can be accessed as throughout the session. I think that should help answer your first question.ACCESS_ACL_ALLOWEDFor your second question, RULE_INIT sets a variable when you save the iRule, so it's a global variable. Try changing your irule to use
andset ::entrypoint
instead and then reference them the same way (e.g.set ::backend_host
). See if that helps.HTTP::uri $::entrypoint
