APM Citrix Client Not Detected Prompt for Microsoft Edge Browser
We have used the iRule documented in this article to resolve the Citrix client not detected prompt for IE 11. Citrix Client Not Detected
However, using Microsoft Edge browser, users are prompted that the client is not detected. There is no compatibility mode for Edge, so would this iRule work even if ([HTTP::header "User-Agent"] contains "Edge")} was added?
Have you tested it? I got the same issue, also Chrome prompts for ICA download.
- FI_2016_187929
I tested it awhile ago and couldn't get it to work. I did go through the logs, but don't remember exactly why it wasn't working. Could be an issue with inserting "X-UA-Compatible" "IE=9" into the Edge HTTP header, but not sure.
- Dmitriy_Sysoev
Hello! Has anyone solved the problem with Chrome detect ICA Client?
