Julio_Navarro's avatar
Julio_Navarro
Apr 27, 2016
APM 401 Response Settings | Adding SessionID Variable
Hello!
I am trying to capture the current session ID when the "http 401 response" negotiation fails. I added a iRule and applied it to the Virtual Server the following command:
    when ACCESS_SESSION_STARTED {
            set sessionid [ACCESS::session data get "session.user.sessionid"]
In the APM HTTP 401 Response object, I added %{sessionid} in the "HTTP response message"
Unfortunately I am not getting getting a value from it.
Please advise
Thank you
J
  • Josiah_39459's avatar
    Josiah_39459
    Historic F5 Account
    You can't access irule variables via the % comamnd in the VPE. On the other hand, it doesn't seem like you even need the irule. Can't you just get the sessionid in the VPE without it?
