Marco_Castro_11's avatar
Marco_Castro_11
Oct 29, 2013
APM 11.4 - Advanced Resouce Assign - Static ACL
I have one doubt regarding how Advanced Resource Assign and static ACL work. Lets say i have configured in Advanced Resource Assign one Expression with: Static_ACL_1 RDP_1,Portal_1,APP_Tunnel_1
And a second Expression with: Static_ACL_2 FullWebtop_1 Network_ACCESS_2
What i want to achieve is in same full webtop have RDP,APPTunel, Portal with static acl 1 assigend but when i start network access also present in that fullwebtop i will have static acl 2 assigned instead of acl1.
Is that possible to configure?
Best Regards, MC
  • if i understand it correctly you want to change the ACL based on the starting of something on the webtop?
    i dont believe that is possible. wouldnt it be enough to assign either ACL1 or ACL2 based on what you put on the webtop?
