Miak
Jan 18, 2010An existing connection was forcibly closed by the remote host
Dear Friends,
I need your help!
I configured the VS for one service for UDP port 8502. we can access the service but we are getting lots of error messages on the server say....!
"An existing connection was forcibly closed by the remote host"
/18/2010 12:23:35 PM | ERROR: An existing connection was forcibly closed by the remote host
1/18/2010 12:23:37 PM | ERROR: An existing connection was forcibly closed by the remote host
1/18/2010 12:23:38 PM | ERROR: An existing connection was forcibly closed by the remote host
1/18/2010 12:23:43 PM | ERROR: An existing connection was forcibly closed by the remote host
1/18/2010 12:23:45 PM | ERROR: An existing connection was forcibly closed by the remote host
1/18/2010 12:23:49 PM | ERROR: An existing connection was forcibly closed by the remote host
1/18/2010 12:23:50 PM | ERROR: An existing connection was forcibly closed by the remote host
1/18/2010 12:23:51 PM | ERROR: An existing connection was forcibly closed by the remote host
(Bigip LC+LTM)Virtual server info: its a public ip on UDP port 8502 UDP.
SNAT is enabled (automap). Using the monitor Gateway ICMP. to monitor pool members.
one more thing is there any other way to monitor UDP services.
Thanks.
- hoolio
Can you post an anonymized copy of the virtual server and udp profile configuration using 'b virtual VIP_NAME list' and 'b profile UDP_PROFILE list'?
For monitoring UDP services, it's ideal to use a UDP monitor in combination with an ICMP monitor:
SOL6143: UDP health monitor operation
https://support.f5.com/kb/en-us/solutions/public/6000/100/sol6143.html
So the UDP monitor checks for an ICMP unreachable message to determine whether the service is down. If the monitor receives no response, it assumes the member is up. So it's ideal to use the UDP monitor with an ICMP monitor to ensure the service is marked down if the node address isn't responding to an ICMP request.
Aaron - Miak
Hi Aaron,
Thanks for the reply.
Please find below
virtual Tracking_Device {
snat automap
pool TRACKING_DEVICE_POOL
destination x.x.x.x.:8502
ip protocol udp
persist source_addr
profile udp udp {
idle timeout 60
monitor Tracking_Device_GW_ICMP {
defaults from gateway_icmp
interval 60
timeout 181
} - hoolio
Hi Mak,
Thanks for posting the config.
Is it possible that the server is trying to send response data after the 60 second idle timeout has expired? Can you try extending the idle timeout to something like 600 seconds and see if the server errors decrease?
Thanks,
Aaron
