Phil_Rudich_735
Jul 31, 2008Alertd & Monitoring Question...
We have alertd setup to monitor nodes in a pool and (obviously) send us emails if a node goes down. However, if we put a node into maintenance - "Disabled" or "Forced Offline" - we still receive messages when working on the server.
Anyone know of a work around to resolve this issue. We would like not to receive emails if we have the node in maintenance, if this is possible. Please advise.
Thanks,
Phil
- Deb_Allen_18Historic F5 AccountHi phil -
Configured monitors continue to run regardless of pool member state, so you would also need to disable the monitor or disassociate it from the pool members.
hth
/deb - Phil_Rudich_735
Thanks for the reply Deb!
Here's another question for you...
In the email notifications for Pool & Node members, is it possible to modify the subject line of the email to specify the actual server name instead of IP address?
Phil - Phil_Rudich_735
Posting again to see if anyone has an answer to my second question above:
Thanks,
Phil
