AFM How ro reset global drop from console
Hi, I mistakenly set the network firewall to drop all traffic not specifically allowed as well as setting the global setting to drop. Security.Options>Network Firewall
Unfortunately now I can't get to the management web console on any interface.
I still have console access so is there a way of changing those settings from the console?
- nathe
Cirrocumulus
Best bet might be to create a management rule from your ip address to allow you to login to the gui and undo your changes.
Without testing, something like this might work:
tmsh modify security firewall management-ip-rules rules add { mgmt-allow { source { addresses add { x.x.x.x } } action accept place-before first } }
Hope this helps
