M_187467
Apr 22, 2015Advantages and disadvantages of using persitence im GTM WIP
Hello friends,
Can anyone explain the pros and cons of using persistence in gtm wwideip ?
Thanks in advance -sam
- Hannes_Rapp
Search for section "Enabling Persistent Connections".
If your application is concurrently hosted in multiple data centers, you may have to use persistence in GTM to ensure consequent requests of a particular end-user are routed to the same data-center. If you only use GTM for DNS, and there is no balancing between the data centers, you should not use persistence in GTM. Use LTM instead.
