rafaelbn's avatar
rafaelbn
7 years ago
Adding used blades to a running Viprion chassis
Hello devs!
I'll be adding 3 new 4340n blades (that were in use in another standalone chassi) to another chassi that currently have 4 4340n blade in it.
To my understaing, other than UCS backups and qkviews, the process is pretty much straight forward. I just have to insert the new blade, TMOS will automatically sync everything on the running blades to the new one. I don't have to format the new blades, right?
My only concearn is since these 3 new blades are not new, they have some old config in it that was not wiped. But I think the sync process will overwrite the old config on these inserted blades.
Is my understanding correct?
Thanks, Rafael.
  • Hi
    Your understanding is correct.
    If you insert new blade, which even have old configuration, into chassis, The VIPRION doesn't only sync configuration but also it re-structure disk partition of the new one, which is same as primary blade.😀
    I hope this answer would be helpful.
