Sean_Peters_148
Mar 19, 2014Add-on Module for LTM 1600
We currently have an LTM 1600 and are thinking of purchasing the Application Acceleration Manager Add-on. Is there a way we can try it for a day or so to see if it's something that would benefit our company?
- Vitaliy_Savrans
Nacreous
I think it's better asked your reseller for trial license for AAM module.
- Thomas_Gobet
You should be careful if you want to use LTM + AAM on a same 1600.
If you're running TMOS 11.4.1 or earlier it's recommended to provisionne AAM as Dedicated only.
