hung_37471's avatar
hung_37471
Sep 05, 2011
Active advance routing
hi all
i'm in new F5 , you can help me , how to active advance routing for F5 ?
i had config active via Zebos command , but it's not work
thanks all
  • hi all
    can you help me to config advance routing ? i would like to config dynamic routing(ospf,..) and policy base routing ,.... but on the interface GUI web , i can't see anywhere to config it ,
    my F5 have license for module advance routing
    pls help me
    thanks all
  • To enable OSPF (or any protocol)
    zebos enable ospf
    To configure the routing
    vtysh
    en
    conf t
    That's all there is to it really.
    If you need i can hunt down the advanced routing module doco.
    Cheers,
