ACCESS::disable in iRule with persisted HTTP/1.1 connection fails
Hello,
I know I should open a case but has anyone seen with 11.4.1 issues with APM using the ACCESS::disable in an iRule causing the dreaded :
http_process_state_prepend - Invalid action EV_BODY_COMPLETE during ST_HTTP_PREPEND_HEADERS (Server side: vip= .. etc
iRule:
if { [HTTP::path] starts_with "/public" }{
ACCESS::disable
It seems if you have a persisted HTTP/1.1 connection, i.e the browser makes a request for a URL (e.g. /private with Connection: keep-alive) that is processed normally by APM (i.e. is authenticated)
.. and then a second request over the same connection is made (e.g. /public) which matches the ACCESS::disable (i.e. should not be authenticated) then causing the above error.
Making the second request without the first works
It took me a while to realise what was wrong, I followed the SOL5922 assuming the backend was not RFC-2616 compliant but no, it is APM that is causing it to choke.
Otherwise is there another way to disable APM on a connection that is not ACCESS::disable or is just forcing all conenctions to HTTP/1.0 is the answer ...
cheers.
- ib_37889
Have you tried closing the connection after ACCESS::disable ? - Martin_Robbins
Thanks but that was "too late", the connection has been reset before it gets to a close statement.
I will share the basic version of the solution I am now using, basically allow if there is a valid session and force client connection close on all other types of requests ...
when HTTP_REQUEST { set f_apmdisable_close 0 if { [HTTP::cookie exists MRHSession] and [ACCESS::session exists -state_allow -sid [HTTP::cookie value MRHSession]] }{ return } elseif { [HTTP::cookie exists MRHSession] }{ set f_apmdisable_close 1 } if { [HTTP::path] starts_with "/public/" }{ WEBSSO::disable ACCESS::disable set f_apmdisable_close 1 } } when HTTP_REQUEST_SEND { clientside { if { $f_apmdisable_close }{ if { [HTTP::header exists Connection] }{ HTTP::header remove Connection } HTTP::header insert Connection Close } } } when HTTP_RESPONSE { if { $f_apmdisable_close }{ if { [HTTP::header exists Connection] }{ HTTP::header remove Connection } HTTP::header insert Connection Close } }The case I opened has not provided any additional help but the code here at least stops the errors and client resets .. I am sure there are improvements to be had.
