Access control to URI based on IP using datagroups
I am attempting to perform access control to a specific URI based on IP address. We would like to permit all internal traffic to anything on the host but would like to restrict a vendors public IP adress to only be able to access a single uri.
This works:
if { [matchclass [IP::client_addr] equals internal-access-dg]}{
} elseif { [HTTP::uri] starts_with "/foo" and not ([IP::addr [IP::client_addr] equals 10.10.10.10/32])}{
reject
We are anticipating having quite a few of these cloud vendors that will need to connect to specific URIs as new applications are developed. I would like to simplify management down the road by creating a datagroup that contains the vendors IP(s) and their URI within the application to do a lookup of the URI then associate the paired IP address to permit access to the URI to only its matching IP address.
I have this built, i know its wrong but im stuck here
} elseif { [class match [string tolower [HTTP::uri]] starts_with external-access-dg] and not ([IP:addr [IP::client_addr] [class search -value external-access-dg starts_with [HTTP::uri]])}{
reject
The external-access-dg datagroup is set up like: /foo:=10.10.10.10/32
Any help would be appreciated.
- pgsmith_120398
Altostratus
i have written this and it appears to be working. Ill test with a vendor sometime and update its success.
when HTTP_REQUEST { Check if client IP address matches the internal IP ranges, if so do nothing if { [class match [IP::client_addr] equals internal-access-dg]}{ If the client IP is not in an internal IP range, check to see if the URI being accessed is secured. } elseif { [class match [string tolower [HTTP::uri]] starts_with external-access-dg]} { if the URI being accessed is secured set the variable hostvar to the value that associated with the URI name set hostvar [class match -value [string tolower [HTTP::uri]] starts_with external-access-dg] If the client IP matches the value associated with the URI name do nothing if { [IP::client_addr] eq $hostvar} { If the URI is protected and traffic is coming from an un-trusted IP reject the traffic } else { reject } } }Any opinions on this or re-workings would be welcome!
