Scooter_372595's avatar
Scooter_372595
Sep 21, 2018
Access Control based on URI and Referer
Hi I have a situation where I need an Irule to control access to a site I control.
The rules I need are:
a) To allow access based on a uri, eg https://mysite.com/scooter/scooterspagers/*
or
b) Allow access to site based on an approved referer header in the request.
I can do one or the other but I cant do both together.
Anyone have any ideas?
thanks
Scooter
  • Hi,
    You can use something like that :
        if { !(([HTTP::host] eq mysite.com and [HTTP::path] starts_with "/scooter/scooterspagers/") or ([HTTP::header Referer] eq "something")) } {
            HTTP::respond 403 content "Forbidden" Connection Close
    I think that it will provide you the expected behavior.
    Regards
    Yann
  • You may use something like this iRule to Allow access to site based on an approved referer header in the request-
    if { ([HTTP::header exists "Referer"]) and
    ([URI::host [HTTP::header value Referer]] eq "approved-referer1.xxx") } {
    Allow Request to go throutht...
    elseif { ([HTTP::header exists "Referer"]) and
    ([URI::host [HTTP::header value Referer]] eq "approved-referer2.xxx") } {
    HTTP::redirect https://www.xxx.com
    I'm using redirect to some web page if connection is not from approved referer1 or referer2 but it can be modified to another action. I hope it helps.
  • Thanks for your suggestions, I couldn't get them to work for me though, however the below did work as required.
    when HTTP_REQUEST { if { not ( [HTTP::uri] contains "/scooter/vespa/" ) } { if { $static::ref_debug } { log local0. "Incoming referer: [HTTP::header Referer]" } switch -glob [string tolower [HTTP::header Referer]] { "https://.scooter.com" { if { $static::ref_debug } { log local0. "From allowed referrer - allow" } return } "http://.example.com*" { if { $static::ref_debug } { log local0. "local domain - allow" } return } default { if { $static::ref_debug } { log local0. "from disallowed referer - redirect" } HTTP::redirect [HTTP::header Referer] } } } }
