René_Posthumus_'s avatar
René_Posthumus_
May 02, 2019
Accept LTM traffic based on IP and variable datagroup
Hi, we are trying to do the following thing on our platform. I'll explain the flow first:
  1. Traffic enters the box using a single VS (EntryVS).
  2. An iRule triggers, looks at the host-header and directs the traffic to the correct VS for that site (ApplicationVS)
  3. A policy triggers there that rewrites the external received host-header to an internally used host-header.
  4. Traffic is forwarded to the backend pool members
So far so good and is working fine. But we need access-lists per ApplicationVS based on Client-IP.
I found an example to do that using in iRule, but we have hundreds of ApplicationVSses and many different access-lists and i don't want to create that many iRules. Many data-groups are acceptable but the iRule then must be aware of which data-group it has to use based on the host-header which, i think, is not available at the CLIENT_ACCEPTED stage.
This is the iRule i have so far:
    when RULE_INIT {
    Drop unknown source IP addresses?  0 = no, 1 = yes
   set static::drop_unknown_sources 1
    Log accepted requests?  0 = no, 1 = yes
   set static::log_accepted_requests 1
   set static::log_dropped_requests 1
 This event is triggered when a client - BIG-IP TCP connection is established
when CLIENT_ACCEPTED {
    Is client IP address defined in the admin_datagroup?
   if { [class match [IP::client_addr] starts_with DATAGROUP_NAME] }{
       Log accepted admin request
      if {$static::log_accepted_requests==1}{
          Log the client IP address:port -> destination IP address:port
         log local0. "request accepted from client: \
                [IP::client_addr]:[TCP::client_port] -> [IP::local_addr]:[TCP::local_port]"
   }  else {
       Request didn't match the conditions for allowing the request
      if {$static::log_dropped_requests==1}{
         log local0. "unknown request rejected from client: \
       Drop request if the option is enabled.  Could also send a reset using 'reject'
      if {$static::drop_unknown_sources==1}{
         drop
How can i make the dategroup variable so that on each request, a host-header is verified and a matching datagroup is used like FQDN_access_DG? Or is there a better solution to this issue ?
Regards, René
