naladar_65658
Altostratus
Nov 20, 2008A Problem with Datagroup Usage
I am having problems with an iRule that uses datagroups. For some reason it just doesn't seem to work at all. Would you fellas mind taking a look at it and maybe point out any grammatical or logic errors it may have? I have ran it through the iRule Editor and the syntax checks out, but I feel like I am missing something basic that the editor just doesn't pick up...
set header_uri [string tolower [HTTP::uri]]
if {[matchclass $header_uri starts_with $::www8_uri]} {
pool WWW8_Pool
} elseif {[matchclass $header_uri starts_with $::oam_uri]} {
HTTP::redirect "https://blank.blank.com/oam/main/oamMain.jsp"
} elseif {[matchclass $header_uri starts_with $::hello_uri]} {
pool Hello_Pool
} elseif {[matchclass $header_uri starts_with $::maui_uri]} {
pool Maui_Pool
} elseif {[matchclass $header_uri starts_with $::publicSite_app_uri]} {
pool PublicSite_App_Pool
} elseif {[matchclass $header_uri starts_with $::calli_web_uri]} {
pool Calli_Web_Pool
} elseif {[matchclass $header_uri starts_with $::true_web_uri]} {
pool True_Web_Pool
} elseif {[matchclass $header_uri starts_with $::documentum_uri]} {
pool Documentum_Pool
pool WWW2_Pool
- JRahm
Admin
Moved this topic to the appropriate forum...fyi - naladar_65658
Altostratus
After performing some extensive logging and after running numerous tests I promoted the iRule mentioned above into production and everything appears to be working fine. I would like to thank all of you for your help.
The only thing that I can think of for why it would not work to begin with is maybe due to a invalid white space character or something of that nature. I stated earlier that when I first promoted the iRule that the default else statement was working, however I was incorrect. I was using the f5 iRule Editor version 0.9.2.0 and Textpad when I wrote it. So it is possilbe something carried over from Textpad that wasn't supposed to.
