Novice71_117393
Mar 19, 2013A monitor question
I have just started playing with F5 LTM and have following questions
How can I configure following on a F5 monitor
1- Mark the pool member as succesful (post failure) after 2 consecutive successful probes
2- Mark the pool member as failed only if 3 consecutive probes are failed.
Thanks in Advance
- Kevin_Stewart
Employee
I would think at a minimum you could tweak the Timeout and Time Until Up values in a standard monitor. Timeout would be some number greater than the interval such that the interval would pass 3 times before marking the node down. Time Until Up would be some number greater than the interval such that the interval would pass 2 times before the node was marked up. The timing of course relies on your application, but I think you can get pretty close to what you're asking for.
Otherwise, if you absolutely need a hard number of attempts (versus time), then a scripted monitor may be your best bet.
