JackieWong_3971
Jan 09, 2009A customised ICMP Monitor
The default ICMP monitor only allows pinging either 1 IP or all IPs if I understand correctly.
Could someone please advise how I could setup only ONE monitor (ICMP) to ping 2 IP addresses such that the pool with this monitor applied to will be shown offline only when both IPs are not pingable.
2 separate monitors is not an option in my case.
Thanks.
Regards,
Jackie
- Pavel_Sestak_69
Type External and shell script? - hoolio
As Paja mentioned you could use an external monitor to do this. You can check the monitoring codeshare for examples (Click here).
Aaron
