wlasagne
Sep 19, 20086.0.3 problem? Network Access with Client Proxy Setting
If I configure Network Access with Client Proxy Setting (autoconfig script) when I try the Network access I get an error: Error initializing proxy
anyone had the same problem?
thx, best regards
Luc
- mal_57091
Hey Luc,
You bet ya! F5 knows about this and they are fixing it in HF-603-1. The CR is CR108535. If this is getting really urgent for you then you should log a case with support and request your company also be added to the list on CR108535 so F5 knows how important it is to fix and can track which customers have hit this bug.
Cheers,
mal
