viprion blade
2 TopicsQuestion regarding F5 Viprion Configuration Migration to VE.
Requires suggestion regarding migration process-from F5 Viprion (B2250 /vCMP Guest -LTM Module) to F5 VE (On VMWare) in same datacenter. Both on F5 version 17.1.1 1.Is there any migration guide available , which includes detailed step by step process ? 2.This will be phased migration (few VS at a time ) or all configuration can be moved to VE at once ? 3.What due care needs to be taken before , during & after migration.317Views0likes6CommentsViprion Balde 4450 Actual Throughput
Hi I am checking the datasheet of Various bales of Viprion and Based on that Blade model 4450 provides 140Gbps throughput(L4/L7) I have some questions here: 1) Is this value full duplex? I mean is it 140Gbps in Send direction and 140Gbps in Receive direction. or it is 70Gbps send and 70Gbps receive? 3) This blade has 100GE ports can I use them to get to this throughout? 2) Is this value is applicable for having the device working in CGNAT mode plus dynamic routing with BGP? If the value is in half duplex then the total capacity of Viprion 4800 will be 560Gbps and because I want to pass about 800Gbps over the box then I must consider using two boxes with DSC and Load-Balancing....Right? Thank you Alireza621Views0likes2Comments
