enable blade
1 Topicviprion - disabled primary slot, cannot re-enable slot
I am running vcmp on a viprion. I disabled the primary slot on the guest, but do not have a way to enable it. If I go to the secondary blade's cluster IP, the option to enable the primary slot is grayed out. Is there another way to enable the primary slot after it has been disabled?399Views0likes2Comments
