2250 blade
1 TopicViprion 2400 -- migrating from 2150B to 2250B
Hi All, I am planing to migrate current 2150B to 2250B on 2400 Chassis. Since its being a while, here are the steps I am planning to perform in order to do successful migration. Kindly guide me if any point is missed or advise for a successful migration : Note : 2 2400 Chassis with single 2150B vCMP Create similar Host/Guest configuration on 2250B with same VLAN, Trunks and Interface configuration Assign same amount of resources to each Guest Guest Create similar Vlans, Trunks, Interface Configurations Migrate Archives from Old 2150B to new 2250B Since 2250 is new and most probably with new version, I'll have to downgrade the version to match the same version as running on 2150B in order to successfully migrate. Verify all configurations under LTM, ASM, APM and GTM One thing, since mixing of different blades aren't possible under same Chassis, who will I configure the Blade with above mentioned steps. Moreover, do i need to configure the same 2400Chassis once 2250 is installed, apologies as i'm newbiw ^_^663Views0likes9Comments
