Technical Articles
F5 SMEs share good practice.
JRahm
Community Manager
Community Manager
Jason follows up John's transitional video from wideIP to pool load balancing with coverage on the static load balancing algorithms available at the pool level in F5 BIG-IP Global Traffic Manager. Global Availability, Round Robin, Ratio, and Topology were all covered in previous videos at the wideIP level and perform the same at the pool level so they are not covered here. The algorithms covered in this video are:
  • Return to DNS
  • Drop Packet
  • None
  • Fallback IP
  • Static Persist
Resources
Version history
Last update:
‎18-Mar-2015 17:00
Updated by:
Contributors
