on
04-Jun-2015
16:03
- edited on
05-Jun-2023
22:29
by
JimmyPackets
Here at F5's LineRate division we often write about our Node.js scripting engine and its use cases by way of script examples. But today I am going to describe to you a less talked about feature in our product. In the world of applications it is not uncommon to have multiple domains mapped to the same IP address.
LineRate provides the ability to attach the same virtual IP to more than one virtual server. This can be useful where an organisation has several applications for its customers, or the case were organisations have merged and IT systems are being rationalized.
In such cases (as shown in the figure below) applications and their domains can have dedicated virtual servers on a LineRate load balancer. When a client makes an HTTP request, the LineRate load balancer inspects the 'Host' field in the HTTP header and directs it to the appropriate virtual server. This is accomplished with the hostname configuration on the virtual server.
hostname configuration example
! virtual-ip vipweb1 ip address 192.0.2.1 80 base vipbase_vip1 admin-status online ! virtual-server example-com lb-algorithm round-robin service http hostname www.example.com attach virtual-ip vipweb1 attach real-server rsweb1 attach real-server rsweb2 ! virtual-server example-net lb-algorithm round-robin service http hostname www.example.net attach virtual-ip vipweb1 attach real-server rsweb3 ! virtual-server default-server lb-algorithm round-robin service http attach virtual-ip vipweb1 default attach real-server rsweb4 attach real-server rsweb5 !
If you haven't tried out LineRate, have a go, it's free. If you have further questions on this or any of the related articles on LineRate at DevCentral, reach out to us. We are here to help.
