Technical Articles
F5 SMEs share good practice.
Custom Alert Banner
Matt_Quill_1086
Historic F5 Account
In a previous post I reviewed the configuration of monitors, profiles and added nodes as part of the LTM + WA configuration with Business Objects.  Part I of this deployment can be found here:  https://devcentral.f5.com/s/weblogs/mquill/archive/2012/07/03/deploying-f5-big-ip-ltm-with-sap-busin...
In this next section we will configure the virtual servers on the LTM, and configure Web Accelerator (WA).  Although this was a single-site deployment, a distributed deployment of Business Objects should see substantial benefits when enhanced with WA.
We will begin by configuring the pools:
Configure Pools:
BOE_WEB_HTTP Pool Configuration
Pool Name
BOE_WEB_HTTP
Configuration
Advanced
Health Monitors
BOE_HTTP
Availability Requirement
All (Health Monitors)
Allow SNAT
Yes
Allow NAT
Yes
Action on Service Down
None
Slow Ramp Time
10 Seconds
IP ToS to Client
Pass Through
IP ToS to Server
Pass Through
Link QoS to Client
Pass Through
Link QoS to Server
Pass Through
Reselect Tries
0
Enable Request Queuing
No
Request Queue Depth
0
Request Queue Timeout
0ms
BOE_WEB_HTTP Pool Members and Ports
Pool Member IP Address
Pool Member Port ID
10.1.86.151
8080
10.1.86.151
6080
10.1.86.151
9080
10.1.86.151
7080
10.1.86.152
8080
10.1.86.152
6080
10.1.86.152
9080
10.1.86.152
7080
10.1.86.153
6080
10.1.86.153
7080
10.1.86.153
8080
10.1.86.153
9080
10.1.86.154
6080
10.1.86.154
7080
10.1.86.154
8080
10.1.86.154
9080
10.1.86.155
6080
10.1.86.155
7080
10.1.86.155
8080
10.1.86.155
9080
10.1.86.156
6080
10.1.86.156
7080
10.1.86.156
8080
10.1.86.156
9080
10.1.86.157
6080
10.1.86.157
7080
10.1.86.157
8080
10.1.86.157
9080
10.1.86.158
6080
10.1.86.158
7080
10.1.86.158
8080
10.1.86.158
9080
10.1.86.159
6080
10.1.86.159
7080
10.1.86.159
8080
10.1.86.159
9080
10.1.86.160
6080
10.1.86.160
7080
10.1.86.160
8080
10.1.86.160
9080
Configure BOE_gzip iRule
In this configuration we have configured an iRule in order to optimize gzip compression on all web logins
if {[HTTP::header exists "Accept-Encoding"]}{
HTTP::header remove "Accept-Encoding"
Configure Business Objects Virtual Server
Navigate to Virtual Servers and click ‘Create’ the Name of our Virtual Server in this example is ‘BOE_BASE_WEB_VS’ Configuration Details of the Virtual Server are below:
Name
BOE_Web_Base_VS
Destination
10.1.86.206
Service Port
8080
Protocol
TCP
Protocol Profile (Client)
TCP
Protocol Profile (Server)
Use Client
OneConnect Profile
BOE_oneconnect
HTTP Profile
BOE_BASE_HTTP
HTTP Compression Profile
None
Web Acceleration Profile
None
Stream Profile
None
SNAT Pool
BOE_SNAT_Pool
Navigate to the ‘Resources’ Section
Default Pool: BOE_Web_http
Default Persistence Profile: BOE_Cookie
Deploying Web Acceleration for Business Objects Portal
Overview: During the process of validating the integration of F5 LTM with SAP BI, we configured the Web Acceleration feature on the F5 BIG-IP. Web Acceleration, when deployed in either a symmetric or asymmetric configuration can accelerate the browser performance, cache static web objects locally on the BIG-IP and address WAN latency which can substantially degrade browser performance. It is important to note that the validation of the BI platform and all client access was simulated locally in the SAP Co-Innovation Lab environment; this means that the full benefit of WA in this particular instance could not be realized. The following steps are best practices implementation steps for deploying WA and compression with F5.
Configure WA Policy
- Under WebAcclerator -> Policies click on the + sign to add a new policy
Policy Name
BOE_Web
Policy
Generic Policy Complete
Requested Hosts
Paf51105.pro.coil, Paf51106.pro.coil
Send Metadata
Always
Metadata Cache Max Size
25mb
IBR Prefix
;wa
IBR Default Lifetime
26 Weeks
X-WA-Header Info
None
Performance Monitor
Disabled
Data Retention Period
30 Days
Click ‘Update’ to commit the changes
- Navigate to Policies and click + to create a policy
- The name we designated is BOE_Generic_policy-Complete
- Accept all defaults and click ‘Update’ (In most circumstances the default settings should be optimal)
Create Optimized Virtual Server:
- Navigate again to the Virtual Servers Section and click on the + to create a new Virtual Server
- Configuration Details are in the table below
Name
BOE_Web_VS
Destination
10.1.86.205
Service Port
8080
Protocol
TCP
BOE_LAN
(Use Client Profile)
OneConnect Profile
BOE_Oneconnect
HTTP Profile
BOE_HTTP
BOE_Compression
BOE_WA
SNAT Pool
BOE_SNAT_Pool
Default Pool
BOE_Web_HTTP
BOE_cookie
Version history
Last update:
‎03-Jul-2012 13:31
Updated by:
Contributors
