on 09-Sep-2011 11:37
Introduction
This article details the process of using F5 Data Manager to generate storage usage reports for all users in an Active Directory (AD) Group. A report is created for each user in the group from a single CIFS file system inventory. The capability of generating such reports is available only with the Advanced Reporting Module.
Problem
Generating a report for each user in an AD environment can be a challenging task if each user for whom the report is to be generated has to be manually entered. This can be achieved easily by just specifying the groups in the File System Report wizard.
Solution
An Advanced File System Detail report can be generated using file criteria and the AD groups to obtain a report for each user in the group. A prerequisite is a CIFS inventory of type Full. The first three steps are setup steps and the fourth step generates the reports. All steps are required.
Step 1: Create a Credential
Specify the credentials needed to contact the domain controller. Contacting the domain controller is required to translate the AD group into the list of individual users.
Step 2: Identifying the Active Directory server
This step is required to set up the domain controller running the Active Directory to be used for the AD Group resolution.
Step 3: Create a File Criteria to use all of the inventoried data
File criteria are used to select a subset of files for a report. In this case, we select all files.
Step 4: Create the storage usage reports using the wizard.
Summary
The use of Active Directory groups makes it easy to run reports for each user in the organization without specifying the user individually.
Author Bio
Arti Sood has been working in the field of quality assurance for over 10 years. She has been instrumental in assuring the quality of Data Manager for the past 3.5 years. Prior to joining F5 Networks, she worked on various applications for network simulation, wireless/wired network access, and peer-to-peer access.
