Hello,
There were some records added in the ZoneRunner when suddenly the issue happened with the error message for each menu as below: Global Traffice → ZoneRunner → Resource Record List → Error: “01020005:3: The requested operation is not implemented yet” Global Traffice → ZoneRunner → Zone List → Error: “General Error” Global Traffice → ZoneRunner → View List → Error: “General Error” Global Traffice → ZoneRunner → Named Configuration → Error: “Error trying to access the database.”
Login to the box showed that it keeps trying to re-starting zrd daemon.
Checking the system log, I found this information (some names are changed): Aug 7 05:30:10 local/usf5-01 err zrd[2030]: 01150403:3: Server failure during update Aug 7 05:30:11 local/usf5-01 err zrd[2030]: 0115020b:3: Errors in config file server reload successful. zone internal.abcd.com/IN: journal rollforward failed: journal out of sync with zone. internal/internal.abcd.com./IN: out of range. zone 148.24.10.in-addr.arpa/IN: loaded serial 4. zone 140.24.10.in-addr.arpa/IN: loaded serial 10.
I found this document in the KB that looks match with the issue: sol10066 (404 Page not found | BIG-IP Documentation). The recommended workaround is to delete the corresponding journal file. Questions: 1. I assume the corresponding journal file that need to be deleted is db.internal.abcd.com..jnl, correct? 2. Will there be a negative impact (service disruption) by deleting that file? Currently this box is still functioning well in answering DNS queries. 3. This box is part of the synchronization group, which consists of three boxes. Only this box which has ZoneRunner error, the other two are accessible from the GUI. Do I need to delete the same journal file in two other boxes? Again, will there be any service disruption caused by deleting the file?
Thank you Raymond.
