Introduction
Zero Trust Network Access (ZTNA) and Zero Trust Application Access (ZTAA) represent two distinct architectural approaches to implementing zero trust application access. ZTAA is emerging as the superior choice for enterprises seeking high-performance, application-centric protection. While both operate under the “never trust, always verify” principle, ZTAA can deliver better performance, lower costs, and provide greater granular control at the application layer, where business-critical assets reside.
As a leader in application access, F5 provides strong authentication and authorization through its mature BIG-IP Access Policy Manager platform. Access Policy Manager, or APM, is a tool that helps organizations with zero trust. It does this by following many of the zero trust principles that organizations like the DoD, CISA, and NIST document. Capabilities like strong encryption, user interrogation, conditional and contextual access, device posture, risk scoring, and API integration with third-party security vendors all contribute to a modern zero-trust access solution. It can be said that F5 and APM were the original zero-trust access solutions long before Forrester coined the term “zero trust” back in 2010.
Understanding the Architectural Divide
ZTNA operates as a network-centric model, creating secure tunnels from users to applications through centralized trust brokers and gateways. This approach can necessitate substantial modifications to the network infrastructure, client software deployment, and, in some cases, re-routing all traffic through tunnel concentration points. ZTNA is well-established and has well-established vendor ecosystems. However, ZTNA can cause performance problems, increase latency, and require big changes to the network architecture.
Zero Trust Application Access is different because it focuses on individual applications. It protects these applications directly by using reverse proxies that are already in place in the business environments where these applications are located or at cloud gateways for cloud-based workloads. This architecture lets users connect directly to applications without tunneling. This means no extra work, keeps existing network investments, and gives you control at the application layer. ZTAA operates agentless in many scenarios and integrates seamlessly with cloud-native, containerized, and microservices architectures.
F5 Zero Trust Direct Application Access
The technical differences create distinct performance profiles. ZTNA’s tunnel concentration can create bottlenecks for high-volume applications and add latency from traffic backhauling. At the same time, ZTAA eliminates these performance issues through direct application access and a distributed proxy architecture. Organizations with large application portfolios, cloud-native environments, or performance-sensitive applications find that ZTAA delivers superior user experience and operational efficiency. It is worth noting that ZTNA solutions are, at their core, just a proxy and use encryption for transport, such as TLS or IPsec.
ZTAA or ZTNA?
Application portfolio size serves as a strong decision criterion. Cost and complexity are also strong considerations. Organizations with fewer than 20 applications, primarily legacy systems, and uniform user bases typically find ZTNA’s network-centric approach adequate. However, enterprises with 20+ applications, cloud-native architectures, and diverse user requirements achieve better outcomes with ZTAA’s application-specific controls.
Performance requirements strongly favor ZTAA for high-volume, real-time, or latency-sensitive applications. Cost considerations also help ZTAA adoption. It can be implemented for a smaller amount of ZTNA costs (depending on how the vendor is doing it) while keeping current network infrastructure investments. Organizations prioritizing rapid deployment, application-by-application rollout, or cloud-first strategies find ZTAA’s minimal infrastructure impact and flexible deployment models advantageous.
Infrastructure strategy alignment matters significantly. ZTNA is best for big network changes and unified SASE plans. ZTAA is best for applications-first approaches, DevOps cultures, and cloud-native changes. The regulatory environment influences decisions, with some compliance frameworks requiring network-level controls that favor ZTNA, while others benefit from ZTAA’s granular application-level security audit trails.
F5’s ZTAA Leadership Position for Federal Agencies
F5 has a strong security position in both federal and commercial landscapes—nearly all the Fortune 50 trust F5 to protect their most mission-critical applications. In addition, federal organizations like the DoD and civilian agencies trust F5 to preserve our nation’s most critical infrastructure. The federal sector was an early adopter of zero trust principles. NIST and CISA were instrumental in designing zero-trust reference architectures. The NIST 800-207 document was a landmark, describing how organizations can approach the implementation of a zero-trust architecture in their environments. The DoD Zero Trust Strategy document builds off this architecture and gets specific by calling out controls under each zero trust pillar. The DoD Zero Trust Strategy document outlines 152 targets and requirements for achieving a mature zero trust implementation. F5 today meets or partially meets 57 of those targets. In addition, recent work was published by the NCOEE/NIST describing a completely independent, tested solution utilizing F5 as a Zero Trust Application Access.
CISA 5 Pillar Maturity Model – Optimal Level
F5 Key Capabilities for Zero Trust Application Access
- F5 BIG-IP APM Identity Aware Proxy (ZTAA) uses access control per request that checks each application access attempt individually. This moves from session-based authentication to transaction-level verification. The platform provides context-aware authentication, evaluating user identity, device posture, location, and application sensitivity for each request. Continuous device posture checking maintains real-time, ongoing assessments throughout user sessions with adaptive multi-factor authentication and risk-based step-up authentication.
- F5’s Privileged User Access (PUA) solution complements ZTAA with DoD-approved capabilities for both privileged and unprivileged user authentication to government systems. The agent-free deployment adds strong authentication, including CAC/PKI and MFA, to old systems that don’t have native support. It also manages temporary passwords and has many audit trails to make sure the system is compliant and secure. The solution is truly zero trust, with neither the end user nor the endpoint knowing the ephemeral password used during the session. Passwords are never stored on disk and are destroyed when the session terminates, creating a strong access solution.
- Full proxy architecture brings visibility into your network data plane. Protocols like TLS 1.3 and Post-Quantum look to strengthen your network security posture, but they also bring potential blind spots. TLS 1.3 key structure is ephemeral by design. This protocol feature is excellent for application security, but it creates potential blind spots for threat hunters. Traditionally, packet capture inspections happen out of band and potentially at a future date. With TLS 1.3, packet inspection out of band becomes increasingly tricky. Since TLS 1.3 is a perfect forward secret by default, the symmetric key used during sessions is ephemeral. This means you will need every ephemeral key generated during a session to decrypt out of band. This creates challenges with the SOC and your threat hunters. F5 can help with its SSL Orchestration solution. By orchestrating decrypted traffic to your security inspection stack and re-encrypting it to your applications, you can utilize all the strong security features of TLS 1.3 and PQC while still providing complete visibility into your data-plane traffic.
Additional Distinctions
F5’s full-proxy architecture enables comprehensive traffic inspection and control that competitors cannot match. F5 provides a unified platform integrating ZTAA, application delivery, and enterprise-grade security capabilities. The platform also offers fast TLS decryption at large scale without slowing down performance. It also supports old applications and new web services.
F5 adds advanced bot detection, fraud prevention, and API security capabilities that pure-play ZTNA vendors lack. F5’s extensive identity provider partnerships include deep Microsoft Azure AD integration with Conditional Access policies, native Okta SAML/OIDC federation, and comprehensive custom LDAP/Active Directory support. Protocol support spans SAML, OAuth, OIDC, RADIUS, LDAP, and Active Directory with flexible deployment across on-premises, cloud, hybrid, and managed service models.
Identity Aware Proxy - Key Capabilities
APM’s Identity Aware Proxy is F5’s Zero Trust Application Access solution. We throw around a lot of acronyms in the IT industry, so I just wanted to get that out of the way and make it clear.
As I mentioned earlier in this post, F5 can currently meet or partially meet 57 of the 152 targets listed in the DoD Zero Trust strategy guide. APM’s IAP solution helps meet many of those 57 targets.
Let’s look at some of these features in the access guided configuration. You can find it in the APM or Access Policy Manager’s GUI. If you would like to see a full walk-through sample config, check out this page for a great write-up and lab.
Authentication and Authorization
Authentication and authorization are at the forefront of any Zero Trust solution. APM provides for robust authentication and authorization integration out of the box. APM has deep integration with Active Directory and supports many of the identity SaaS providers, such as Okta, Ping, SailPoint, and Azure Entra ID. In the image above, MFA is a capability built into the GUI, which makes it very easy to implement a two-factor solution within your ZTAA solution. MFA should be a component of every Zero Trust solution, and F5 makes it easy to integrate with your favorite identity provider.
Conditional and Contextual Access
Another key component of any ZTAA solution is conditional and contextual access. The new perimeter in a zero-trust world doesn’t really exist. We should prioritize protecting the data and application, rather than focusing on our network perimeter security. This is not completely true, as we will keep using network firewalls. But the main idea of zero trust is about data and strong identity, not gateways into our networks.
Based on that last sentence, we must be able to interrogate both the user and the device they are accessing from. This involves checking a device’s posture for an active firewall or determining its location and the time of day of access. Users should be required to provide a strong identity to include MFA and ABAC controls.
In the image below, we show the contextual configuration options for Identity Aware Proxy. This capability makes it easy to configure complex if-then logic flows. Another strong capability sometimes overlooked is APM’s ability to query third-party systems for additional context. The HTTP Connector, as shown below, allows the administrator to configure a third-party risk score provider or additional telemetry for access decisions. This is all done via API calls, and so it makes interoperability seamless with other ecosystem vendors.
Conclusion
ZTAA is the change from zero trust architecture to application-focused security. It offers better performance, strong identity, lower costs, and more flexibility than traditional ZTNA approaches. F5 leads this transformation through its authentication and authorization technology platform, comprehensive application security capabilities, and proven enterprise deployment success across federal and civilian agencies.
Organizations evaluating zero trust solutions should prioritize ZTAA for their application portfolios, cloud-native environments, and performance-critical deployments. F5’s unified platform approach, technical differentiators, and market-leading capabilities make it the clear choice for enterprises seeking comprehensive zero-trust application access solutions that scale with business growth and digital transformation initiatives.
