Working on msmq load-balancing
Hi team: I’m working on msmq load-balancing,but there is a problem when reading and value “0xc00e0003” which means “MQ_ERROR_QUEUE_NOT_FOUND” in the capture file.However,it’s works when direct to the real server.If there is any suggsetions?
Thanks a lot!
![Image Text](/Portals/0/Users/157/53/177053/errormsmq.png?ver=2017-10-22-234223-330)
Ok. The problem is that MSMQ queue messages are stored in a physical location on the hard disk. Therefore, as you move to a different physical server, the queue is not there. There are several solutions for this problem (the right solution for you depends on the performance and reliability requirements), includong using a separate messages server or creating queues with the same name pn all the servers and avoiding transactional messages. You may alsp find the following article useful: Oil and water - MSMQ transactional messages and load balancing | Microsoft Learn Hope that helps, Yoel Arnon
Thanks for your reply,and there is just one physical server when testing.
