Hello,
We have few viprion 2400 in our network with V11.5, can we upgrade vcmp guests to higher version without upgrading host.
Hello,
Hi Mike~ I believe you can.
K14088: vCMP host and compatible guest version matrix talks about how the vCMP host allows you to run a vCMP guest software version, which can be either the same version or a different version than the host, which is 11.0.0 and later.
and
K15930: Overview of vCMP configuration considerations has a section on common upggrade questions and notes that the only requirements are based on the host and guest versions supported by your hardware.
Hope that helps!
ps
