Is there any way to issue a TCL [ACCESS::session data set ] within an LTM Policy decision? I want to be able to set a session variable based on a set of conditions.
Thanks.
Thanks.
Not today. You’d need to use an iRule.
OK, that’s what I figured. I’m going to try using a negative match for the rules that I want to fall thru the policy logic for a TCL set variable option then if the variable does not exist, the iRule will take over. In the iRule I will use the “[info exists sso_config]”. I assume that in V12 things will change.
