Unexpected modify_string_class behavior
Basically, I need to update a datagroup/class list to include specific name/value pairs. If existing entries are trounced, it’s okay. Is modify_string_class the correct way to do this?
Here are a few more details regarding the behavior I don’t understand:
Given the following string class:
class testclass {
“valuea 1”
“valueb 2”
I would expect to modify the members of this class by calling modify_string_class() with the following array of LocalLBClassStringClass class_members, which would result in these (and only these) members remaining.
“valuea .9”
“valueb 2”
For some reason, I recieve the following exception when submitting the request:
Exception calling “modify_string_class” with “1” argument(s): "Exception caught in LocalLB::Class::modify_string_class()
Exception: Common::OperationFailed
primary_error_code : 16908342 (0x01020036)
secondary_error_code : 0
error_string : 01020036:3: The requested string class member (testclass valuea .9) was not found."
At line:1 char:27
+ $class.modify_string_class( <<<< $multi)
Your logic is correct. If you are receiving this error message, I’d report this to product support and get you in the queue for a hotfix.
Short term solutions:
1. call delete_class() and then create_string_class() with all the new members.
2. call delete_string_class_member() for the old value and then add_string_class_member() for the updated value.
-Joe
