Hello,
I’ve got a simple ruby iControl script that can successfully enable connection mirroring on a virutal server, but trying to set the state to DISABLED fails. In fact trying to set the mirror state to STATE_DISABLED on a virtual server that already has the mirror state disabled will actually ENABLE the mirror connection state!
i’m pretty sure i’m using the 11.0.0.1 gem, but i have both the 11.0.0.1 gem and the 10.2.0.2 gem installed and i’m not sure how to specify/tell which is being used. I’m using Ruby v1.9.2
Here is my sample code- the mirror state value is hardcoded inside the script. in case the wiki messes up the formating, you can find the script here: F5 Ruby iControl script that is supposed to be able to enable/disable the connection mirror state of a virtual server, but always enables it despite sending "STATE_DISABLED" as the desired state · GitHub
require “rubygems”
require “f5-icontrol”
require “getoptlong”
require “rdoc/usage”
options = GetoptLong.new(
[ “--bigip-address”, “-b”, GetoptLong::REQUIRED_ARGUMENT ],
[ “--bigip-user”, “-u”, GetoptLong::REQUIRED_ARGUMENT ],
[ “--bigip-pass”, “-p”, GetoptLong::REQUIRED_ARGUMENT ],
[ “--vs-name”, “-n”, GetoptLong::REQUIRED_ARGUMENT ],
[ “--help”, “-h”, GetoptLong::NO_ARGUMENT ]
bigip_address = ‘’
bigip_user = ‘’
bigip_pass = ‘’
vs_name = ‘’
options.each do |option, arg|
case option
when “--bigip-address”
bigip_address = arg
when “--bigip-user”
bigip_user = arg
when “--bigip-pass”
bigip_pass = arg
when “--vs-name”
vs_name = arg
end
end
RDoc::usage if bigip_address.empty? or bigip_user.empty? or bigip_pass.empty? or vs_name.empty?
Initiate SOAP RPC connection to BIG-IP
bigip = F5::IControl.new(bigip_address, bigip_user, bigip_pass, [“LocalLB.VirtualServer”, “LocalLB.Pool”]).get_interfaces
puts ‘Connected to BIG-IP at "’ + bigip_address + ‘" with username "’ + bigip_user + ‘" and password "’ + bigip_pass + ‘"…’
bigip[“LocalLB.VirtualServer”].set_connection_mirror_state([vs_name],[“STATE_DISABLED”])
