TMSH APM policy modify
Hello,
I am trying to write a script that will ouput tmsh commands to update an APM policy. What it needs to do is to add a new ACL to LDAP group mapping. So the command I use is something like this:
modify apm policy agent resource-assign TEST_POLICY  rules { { acls add { my_acl } } }
However instead of appendig it just deletes all existing ACLs. What am I doing wrong? :slight_smile:
Regards
Carol
no direct experience, but have you tried “acls add” and then including the old and new ones?
i tried this and with adding old a new it works, not what you want exactly but perhaps a workable workaround.
the whole apm policy agent tmsh commands are a bit different, they seem more intented to build something from scratch then modifying elements afterwards
someone else was looking for something similar but didn’t get a answer either:
https://devcentral.f5.com/s/question/0D51T00006i7hpq/adding-new-rules-to-a-resourceassign-using-tmsh
you can always open a support ticket, perhaps they know or there is an RFE for this.
Thank you! I totally forgot to come back. I will probably have to go with the first option. Thanks again
