TACACS+ External Monitor (Python)
Problem this snippet solves:
This script is an external monitor for TACACS+ that simulates a TACACS+ client authenticating a test user, and marks the status of a pool member as up if the authentication is successful. If the connection is down/times out, or the authentication fails due to invalid account settings, the script marks the pool member status as down.
This is heavily inspired by the Radius External Monitor (Python) by AlanTen.
How to use this snippet:
Prerequisite
  1. Create the directory /config/eav/tacacs_plus on BIG-IP
  2. Copy all contents from tacacs_plus package into /config/eav/tacacs_plus.
Installation
On BIG-IP, import the code snippet below as an External Monitor Program File.
Monitor Configuration
Set up an External monitor with the imported file, and configure it with the following environment variables:
KEY: TACACS+ server secret
USER: Username for test account
PASSWORD: Password for test account
MOD_PATH: Path to location of Python package tacacs_plus, default: /config/eav
TIMEOUT: Duration to wait for connectivity to TACACS server to be established, default: 3
Troubleshooting
SSH to BIG-IP and run the script locally
$ cd /config/filestore/files_d/Common_d/external_monitor_d/
# Get name of uploaded file, e.g.:
$ ls -la
-rwxr-xr-x. 1 tomcat tomcat 1883 2021-09-17 04:05 :Common:tacacs-monitor_39568_7
# Run the script with the corresponding variables
$ KEY=<my_tacacs_key> USER=<testuser> PASSWORD=<supersecure> python <external program file, e.g.:Common:tacacs-monitor_39568_7> <TACACS+ server IP> <TACACS+ server port>
Code :
#!/usr/bin/env python
# Filename  : tacacs_plus_mon.py
# Author    : Leon Seng
# Version   : 1.2
# Date      : 2021/09/21
# Python ver: 2.6+
# F5 version: 12.1+
# ========== Installation
# Import this script via GUI:
# System > File Management > External Monitor Program File List > Import...
# Name it however you want.
# Get, modify and copy the following modules:
# ========== Required modules
# -- six --
# https://pypi.org/project/six/
# Copy six.py into /config/eav
# -- tacacs_plus --
# https://pypi.org/project/tacacs_plus/ | https://github.com/ansible/tacacs_plus
# Copy tacacs_plus directory into /config/eav
# ========== Environment Variables
# NODE_IP   -   Supplied by F5 monitor as first argument
# NODE_PORT -   Supplied by F5 monitor as second argument
# KEY       -   TACACS+ server secret
# USER      -   Username for test account
# PASSWORD  -   Password for test account
# MOD_PATH  -   Path to location of Python package tacacs_plus, default: /config/eav
# TIMEOUT   -   Duration to wait for connectivity to TACACS server to be established, default: 3
import os
import socket
import sys
if os.environ.get('MOD_PATH'):
    sys.path.append(os.environ.get('MOD_PATH'))
else:
    sys.path.append('/config/eav')
# https://github.com/ansible/tacacs_plus
from tacacs_plus.client import TACACSClient
node_ip = sys.argv[1]
node_port = int(sys.argv[2])
key = os.environ.get("KEY")
user = os.environ.get("USER")
password = os.environ.get("PASSWORD")
timeout = int(os.environ.get("TIMEOUT", 3))
# Determine if node IP is IPv4 or IPv6
family = None
try:
    socket.inet_pton(socket.AF_INET, node_ip)
    family = socket.AF_INET
except socket.error:  # not a valid address
    try:
      socket.inet_pton(socket.AF_INET6, node_ip)
      family = socket.AF_INET6
      sys.exit(1)
# Authenticate against TACACS server
client = TACACSClient(node_ip, node_port, key, timeout=timeout, family=family)
try:
  auth = client.authenticate(user, password)
  if auth.valid:
    print "up"
  # EAV script marks node as DOWN when no output is present
  pass
Tested this on version:
12.1
