I’m having some issues uploading a file to the BigIP. I use Java and here’s a rough code sample of what I’m trying to do:
Interfaces interfaces = new Interfaces();
interfaces.initialize([address], [username], [password]);
SystemConfigSyncBindingStub stub = interfaces.getSystemConfigSync();
SystemConfigSyncFileTransferContext fileTransferContext = new SystemConfigSyncFileTransferContext();
fileTransferContext.setChain_type(CommonFileChainType.FILE_FIRST_AND_LAST);
File inputFile = new File(“D:\\testing.txt”);
byte[] fileData = new byte[(int)inputFile.length()];
FileInputStream str = null;
try {
str = new FileInputStream(inputFile);
str.read(fileData);
fileTransferContext.setFile_data(fileData);
} finally {
if(str != null) {
try {
str.close();
} catch(IOException ioe) {}
stub.upload_file(“/home/[my_user]/test/testing.txt”, fileTransferContext);
In this example I use a file with only a few characters inside so one chunk is enough.
Each time I run this code, I get the error:
Exception caught in System:
iControl:System/ConfigSync::upload_file()
Exception: Common::OperationFailed
primary_error_code : 16908289 (0x01020001)
secondary_error_code : 0
error_string : Error opening file for write operations
If I call other methods like upload_configuration() or get_version() they work fine.
I also tried using the iControlIntermediary like so:
ConfigSync configSync = new ConfigSync([username], [password], [bigip]);
configSync.uploadFile(“D:\\testing.txt”, “/home/[my_user]/test/testing.txt”);
With this code however I get a: (401)F5 Authorization Required error.
We are using a BIG-IP version 9.4.7
My account role is Administrator and my terminal access is: Advanced shell.
Any help would really be appreciated as I have no idea what could be wrong.
Thank you in advance.
