Sync Configuration without Traffic Group
Hi all, I have 2 BIGIP that have each of them have a VLAN_groupe that do only SSL chippers change between client and internal Bigip’s each of them is a standalone but both of them have the same configuration because of one of them in DR I will need to design sync between to standalone device VS POOL NOOD CERTS AND PROFILES I found that article: Devious Networks: BIG-IP Folders but it not works for me in VS
We also have a BIGIQ but BIGIQ can’t import configuration because of the VLAN-group
Hi Igorzhuk,
you may look into the SCF (Single Configuration File) feature.
Using SCF allows you to export the configuration to a flat configuration file and import the configuration (after cleaning any unnessesary objects or chaning them as needed) back to a different unit.
K13408: Overview of single configuration files (11.x - 14.x)
K81271448: Merging BIG-IP configuration objects into the running configuration using tmsh
Wrap the SCF approach into a shell script which save the config on unit A, does some text parsings, file transfers and imports the SCP to unit B and you will get a tailordered Config-Sync for all the configuration objects you need…
Yeah, I know its not the stuff you where looking for, but at least it does what your asking for… :wink:
Cheers, Kai
