iControl is ignoring a start_transaction request using SOAP directly with the SOAP Header session element. For technical reasons, I am unable to use an HTTP Header. Does anyone have an idea of why this is the case?
See the comment below for the SOAP code segments.
I’ve reformatted the sections of XML so that they display correctly. iControl is ignoring a start_transaction request using SOAP directly with the SOAP Header session element. For technical reasons, I am unable to use an HTTP Header. Does anyone have an idea of why this is the case? Using SOAP directly, I’m requesting a Session ID: ~~~ ~~~ iControl returns the Session ID, 31: ~~~ HTTP/1.1 200 OK Date: Wed, 02 Apr 2014 22:22:34 GMT Server: Apache Set-Cookie: BIGIPAuthCookie=*****; path=/; Secure; HttpOnly Set-Cookie: BIGIPAuthUsernameCookie=*****; path=/; Secure; HttpOnly SOAPServer: EasySoap++/0.6 X-Frame-Options: SAMEORIGIN X-Content-Type-Options: nosniff X-XSS-Protection: 1; mode=block Content-Security-Policy: default-src ‘self’ https://sentinel.whitehatsec.com https://api.ctscloud.com https://key.ctscloud.com ‘unsafe-inline’ ‘unsafe-eval’ Strict-Transport-Security: max-age=16070400; includeSubDomains Keep-Alive: timeout=4, max=100 Connection: Keep-Alive Transfer-Encoding: chunked Content-Type: text/xml; charset=“UTF-8” 31 ~~~ Using the Session ID of 31, I send a Start Transaction Request: ~~~ 31 ~~~ iControl returns: ~~~ HTTP/1.1 200 OK Date: Wed, 02 Apr 2014 22:23:58 GMT Server: Apache Set-Cookie: BIGIPAuthCookie=*****; path=/; Secure; HttpOnly Set-Cookie: BIGIPAuthUsernameCookie=*****; path=/; Secure; HttpOnly SOAPServer: EasySoap++/0.6 X-Frame-Options: SAMEORIGIN X-Content-Type-Options: nosniff X-XSS-Protection: 1; mode=block Content-Security-Policy: default-src ‘self’ https://sentinel.whitehatsec.com https://api.ctscloud.com https://key.ctscloud.com ‘unsafe-inline’ ‘unsafe-eval’ Strict-Transport-Security: max-age=16070400; includeSubDomains Keep-Alive: timeout=4, max=100 Connection: Keep-Alive Transfer-Encoding: chunked Content-Type: text/xml; charset=“UTF-8” 0 ~~~ The subsequent Create Node request executes immediately instead of being queued with the transaction, despite having the same Session ID included: ~~~ 31 myTestNode4 192.168.1.14 5 ~~~ iControl responds and the Address node is immediately created: ~~~ HTTP/1.1 200 OK Date: Wed, 02 Apr 2014 22:26:14 GMT Server: Apache Set-Cookie: BIGIPAuthCookie=*****; path=/; Secure; HttpOnly Set-Cookie: BIGIPAuthUsernameCookie=*****; path=/; Secure; HttpOnly SOAPServer: EasySoap++/0.6 X-Frame-Options: SAMEORIGIN X-Content-Type-Options: nosniff X-XSS-Protection: 1; mode=block Content-Security-Policy: default-src ‘self’ https://sentinel.whitehatsec.com https://api.ctscloud.com https://key.ctscloud.com ‘unsafe-inline’ ‘unsafe-eval’ Strict-Transport-Security: max-age=16070400; includeSubDomains Keep-Alive: timeout=4, max=100 Connection: Keep-Alive Transfer-Encoding: chunked Content-Type: text/xml; charset=“UTF-8” ~~~
It turns out that the transaction timeout was expiring. It’s set by default to 5 seconds, and since I was performing each request manually, I exceeded the timeout. I used the set_transaction_timeout request, which is specific to each session, to work around it.
