SSO functionality for Revese Proxy
We are looking for SSO functionality on Reverse Proxy with BIG-IP 4000. If multiple sites are published through Reverse Proxy and users access any one of those site, it will redirect user to login page and BIG-IP will capture the user credential. And if the user tries to access other sites through reverse proxy, it should not ask credential to user, F5 should be able to push user credential to other site. Can it be done on F5, and what is logical configuration is required to achive the same.
This is possible with the APM module I would have thought. Apologies but I don’t know enough to advice on it’s configuration.
There are several ways to achieve SSO, indeed you need APM module for most of them. See this file for details: myF5
Steve is absolutely correct. This is a primary function of the Access Policy Manager (APM) module. Also understand that under most conditions, the BIG-IP platform IS already a reverse proxy. So APM can collect user credentials and then use those credentials to transparently authenticate the user to different applications behind the reverse proxy. Moreover, the type of SSO can be different for each application (ie NTLM, Kerberos, form, Basic, etc.) and you can even authenticate across federated platforms with SAML.
Thanks Gabriel for sharing iputs and document link.
