I need a little urgent help with SSL passthrough. Basically, I want to know how to achieve SSL pass through? as it stands, its not working.
at the moment I have a VS listening on port tcp/443 and pool listening on tcp/18103, I am not using any IRULEs. I have already tried creating client and SSL profiles with SSL pass through enabled but still no use.
Seems to me that the option you are reffering to is probably not the one you are looking for - it is suitable when you offload or bridge SSL and the ciphersuite negotiated between the client and server is not supported - then the traffic passes through. Is this your use case? If you want to use SSL Passtrough (meaning no SSL inspection at all) then simply do not attach either client or server SSL profile.
What kind of VS are you configuring? Standard? Forwarding? Attaching a http profile to Standard VS essentially makes it L7 VS (and makes traffic flow a little bit different then without http profile). Start with basic troubleshooting like verifying connectivity serverside using telnet/curl/nc (or whatever would work on your destination port/service you are loadbalancing to). SNAT is required when you would deal with assymetric routing - are you using SNAT pool or automap to float/non-float address?
I would start with setting client side http profile to none (to force your VS to establish TCP connection with serverside without waiting for client data) and setting the SNAT to automap (to exclude any problems with your SNAT pool).
I think that at this point this is irrelevant whether you use standard or forwarding VS. Either way you are trying to full proxy a connection and SNAT and using forwarding VS gives you advantages of FastL4 profile - which we do not care about for now
