ssl pass though https VIP is not working
hi
I configured an https VIP on LTM ( performance L4 VIP ) ;it did not work then tried standard VIP with http profile as none ; still it did not work..
What is the correct way to setup ssl pass though URL https:/xyz.abc.com as VIP on LTM.SSL certs are there on server only; we do not want them on LTM.
THANKS MAYANK
have you checked tcpdump/ssldump? what did you get?
nopes.. i think some mistake in selecting correct profiles:-
please guide me what type of vip is needed and whaat profiles need to be selected..
certs are there on servers; ltm has to be in ssl pass through mode and vip is an https url..
sol12015: Configuration requirements for SSL virtual servers, profiles, pools, and monitors
e.g.
config
root@(ve11c)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar
ltm virtual bar {
    destination 172.28.24.10:443
    mask 255.255.255.255
    pool foo
    profiles {
        fastL4 { }
    source 0.0.0.0/0
    source-address-translation {
        type automap
    vs-index 18
root@(ve11c)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool foo
ltm pool foo {
    members {
        200.200.200.101:443 {
            address 200.200.200.101
 test
[root@ve11c:Active:In Sync] config  curl -Ik https://172.28.24.10
HTTP/1.1 200 OK
Date: Sun, 22 Mar 2015 05:36:29 GMT
Server: Apache/2.2.3 (CentOS)
Last-Modified: Sun, 09 Feb 2014 08:39:51 GMT
ETag: "41879c-59-2a9c23c0"
Accept-Ranges: bytes
Content-Length: 89
Content-Type: text/html; charset=UTF-8
I configured performance(layer 4) VIP though GUI ;it automatically chose fastl4 profile in advanced section;pool members are also listening on port 443 ; what is wrong in my config ? all looks green on ltm but url does not open..
I used snat pool
ok
i hv access to gui only;please tell me how to capture tcp dump from gui ; how to start,stop and get the file safely ? i will do this if automap does not work
its 11.4.1
i think you had better use cli.
It worked with automap. I greatly appreciate your tech skills and helping nature!
Please advise me the concept why it worked with automap and not with specific snat pool? and why we need performance(layer 4) type of VIP in this case ?
Thanks Mayank
you may check if server (pool member) have configured route for snatpool ip to bigip correctly.
either standard (without http profile) or performance layer 4 virtual server type should work.
check sol8082 about the difference between standard and performance layer 4 virtual server types.
sol8082: Overview of TCP connection setup for BIG-IP LTM virtual server types
ok so servers(pool members) must have layer3/4 connection to snat pool ips!!
I only asked firewall team to check open/verify connection from source ip( snat pool IPs) to server1:443,server2:443.. I think 2 more things were needed:- 1. firewall team need to open this connection in both directions on firewall.( from server:443 to snat ips as well) 2. need to ping snat pool ips from server to check layer 3 connection..
