SSL Certificate
Is this necessary to Export all SSL certificate from OLD F5 to New F5,which are not expire yet and we are replacing with NEW F5
Necessary and All make me want to say no. No, you don’t have to export any certificate you are not using and do not plan to use in the future. Similarly you don’t have to export any certificate you no longer want to use. You can export any certificate and key you want to continue using, or just the keys and transfer the certs via UCS, or include the keys in the UCS and transfer nothing.
We cannot Migrate UCS as old is 9.4.x and New IOS is 11.5.4 , so can we only import the Certificates if necessary
