SSL Certificate format
F5 ssl offload Supports several certificate format ?
.cer 、crt 、p12、pfx ,anything else ?
All info on - 404 Page not found | BIG-IP Documentation
The F5 supports the PEM format of those filetypes. I.E. Is readable by a human versus it looking like a foreign language when you open the file. If the certs are not PEM, they can be easily converted using the openssl command.
Check this site out for the commands to help you convert: https://www.sslshopper.com/ssl-converter.html
