I have a pair of GTMs that operate as a sync group, two HA pairs of LTMs, and four virtual servers - two on each set of LTMs so LTM-A has a virtual server for service MyWebSrv and one for MyOtherWebSrv, and LTM-B has a backup virtual server for service MyWebSrv and one for MyOtherWebSrv that can become active if LTM-A is unavaible.
I want to set up my Wide-IP so that internal users get the pool for MyWebSrv, but external users get the pool for MyOtherWebSrv. They’re separate virtual servers, so I can’t just use the translated vs external address on a single virtual server. Both MyWebSrv and MyOtherWebSrv are on the same LTM, so I can’t do it by data center.
What’s the best way to set this up? Have the two servers for each service in a pool and use an iRule to give out the correct pool based on the query source? (see below)
To add extra detail in case I’m not explaining it well above:
LTM-A has virtual servers MyWebSrv on 10.1.1.100, and MyOtherWebSrv on 10.1.1.200
LTM-B has virtual servers MyWebSrv on 10.2.2.100, and MyOtherWebSrv on 10.2.2.200
The GTMs are authoritative for lb.example.com.
I want internal DNS queries for thing.lb.example.com get [10.1.1.100 if LTM-A is active or 10.2.2.100 if LTM-A is offline].
External DNS queries for thing.lb.example.com will get [10.1.1.200 if LTM-A is active or 10.2.2.200 if LTM-A is offline]
The iRule would be something like this, if my internal queries came from NS 10.10.10.10:
when DNS_REQUEST {
if { [IP::addr [IP::remote_addr] equals 10.10.10.10] } {
pool MyWebSrv-pool
pool MyOtherWebSrv-pool
Thanks!
